Check the SPI modes. There are four options, brute force through them to find if one works better. SPI clock polarity should be chosen such that data is registered during half-way of the stable data bit. If the clock polarity is wrong, then the data is registered during the transition and setup/hold times become really important. And when the clock polarity is wrong, it is quite random which of the adjacent bit gets clocked in, so once you change to right polarity you might or might not need to swap the other option ("phase") as well. Therefore going through the 4 combinations is needed.
Then, good grounding. On FFC, signal-groung-signal-ground-signal arrangement is highly recommended. If you lack pins, then substitute ground with power, i.e. signal-ground-signal-power-signal, but have physically small bypass caps between power and ground at both ends of cable. PCB should be with continuous ground plane and ground via right at every ground connection.
Series termination of SPI signals is a good idea to stop ringing, 47R is fine.
But the fact that adding just 10pF of capacitance makes me think it's a clock polarity problem after all.
