Maybe you missed it, but above it has already been explained that ringing does not depend on clock frequency but on rise and fall times.
Let me repeat: In my measurements ringing is no problem as it's amplitude is always less than 0.8 V, even when the MCU produces the fastest signal edges it can. And the larger spikes decay rapidly, lets say within 10 nsec. So the hardware works the same at much higher clock rates, e.g. 50 MHz. Next time i have some cable SPI on my desk, i will show similar measurements for SPI.
Regards, Dieter
