Guys, I'm sorry if you are upset with me, it's not what I wanted.
Post the information we are asking and we won't be upset
. (No, really, I'm having a good time with this thread, mostly thanks to Postal2.)
I mean the low hanging fruit stuff which takes less than a minute for you to produce. Screenshot of schematic, layout, maybe a photograph of the device. It's not like you have to take it using a film camera, develop the film and scan the pictures.
I have used a logic analyser to confirm that the timing is correct as per the detailed timing diagrams from the data sheets that I'd missed.
That would be easier to verify if you posted a screen capture or photograph of the logic analyzer screen.
I had a look around with the scope today and there was a lot of ringing. So I added the 49R9 to the clk line as a quick test as it had been suggested that was the most important trace. Yes, I should add them to all, but it's particularly fiddly to do. I'll look at it tomorrow.
Very excessive ringing
can cause issues like this, so it's a real possibility. Definitely add the resistors to the rest of the traces as well. At the driver; so MISO would be at the slave, others at master.
Seeing the scope image would be interesting. Some ringing which actually is not there will also result in from the loop of the ground clip, so if you still have the little metal springy thing which came with the oscilloscope probe (it is easy to lose it), use that. Scratch some solder mask off from the ground plane so you can touch the spring thing, and probe the signal.
And oh, always probe at the receiver pin. Especially now as you have the series termination resistor in place; by definition of source termination signal is only valid at the receiving end of the transmission line.
At 5MHz do I not need any filtering either side of the FFC cable?
5MHz is the data rate and does not mean much else except maybe giving an ultimate limit to how much you can allow your filter to slow down the signal.
Filtering has two different purposes, to reduce emissions and/or to increase immunity. But you should definitely start by fixing the layout (including your cable signal arrangement) because if it's proper then you should not be having emission/immunity problem in the first place. After proper layout, terminate the signals with the source series resistor and it's very unlikely you need any extra filtration. Well increasing the series resistance value beyond the exact characteristic impedance of the trace already
is filtering.
