Author Topic: MIPI-DSI immunity to switching noise?  (Read 1333 times)
Offline ricko_ukTopic starter
« on: November 25, 2024, 12:14:56 am »
because of PCB layout constraints I have to place a synchronous-type switching regulator (24V in to 3V3 out running at 2A) next to the MIPI-DSI connector.
The inductor is fully shielded and all the power-path traces are as short as they can be (literally 2-3 mm long).
How immune is MIPI-DSI to switching noise? Is it ok to place the switching regulator right next to it?
Thank you
« Last Edit: November 25, 2024, 12:24:27 am by ricko_uk »
Offline uer166
Re: MIPI-DSI immunity to switching noise?
« Reply #1 on: November 25, 2024, 12:30:00 am »
Looks like they're ~50 Ohm SE impedance diff pairs, so the usual applies:
Don't cross GND slots, reduce crosstalk by keeping the offenders away by 5-10 prepreg heights, either don't flood top layer with GND, or if you do, stitch it every 1/10th wavelength of the signal in question, etc etc.
It doesn't seem particularly sensitive, just like most high-speed controlled impedance interfaces.
« Reply #2 on: November 25, 2024, 02:25:03 am »
Thank you @uer166 :)
Offline Pbtz
  • Country: br
« Reply #3 on: November 26, 2024, 09:52:10 am »
In my experience MIPI is fairly robust in general. I've made it work over 10-inch bodge wire.
« Reply #4 on: November 26, 2024, 04:48:18 pm »
Thank you Pbtz.
At what speeds did you do that?
