Author Topic: LCD with 16pins instead of 14pins?  (Read 2052 times)
Offline alank2Topic starter
« on: April 29, 2015, 04:21:02 pm »
I bought some 40x2 displays off ebay.  One says HD44100FS on it and the other says uc-40207 on them.  Both have 16 pins instead of 14 pins, but the 15/16 are NOT connected to the lcd backlight.  They might be pretty old.  Was there a different pinout before the 14pin one?  Both are samsung displays.  One says TM402CQ on the pcb.  Any ideas?
Offline macboy
Re: LCD with 16pins instead of 14pins?
« Reply #1 on: April 29, 2015, 05:23:43 pm »
You may need to trace the pins back to the controller IC to reverse engineer the pinout for yourself.
Offline nixfu
« Reply #2 on: April 29, 2015, 05:50:26 pm »
15/16 are usually for the back-light, I have never seen them used for anything else.
« Last Edit: April 29, 2015, 05:52:44 pm by nixfu »
Offline Skimask
« Reply #3 on: April 29, 2015, 06:12:55 pm »
40x2 sometimes have a 2nd enable pin.  1 enable gets the first 20x2, 2nd enable gets the last 20x2.
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline Pjotr
« Reply #4 on: April 29, 2015, 06:31:39 pm »
Pins 1 - 14 are pretty standard. Pins 15/16 are for the back light, whether or not there is a LED back light mounted. However the polarity of pins 15/16 varies from LCD to LCD and can sometimes be jumpered for correct polarity.
