Author Topic: Choosing copper wire thickness  (Read 1093 times)
Offline whattyTopic starter
  • Country: in
« on: March 13, 2023, 05:08:42 am »
I had designed a fly-back transformer now i need to wind it on winding i need to choose the wire gauge thickness. Can any one help me to choose the correct gauge or direct me.
i will provide data some necessary data
operating frequency : 65KHz
iP peak :1.08 A
iS peak: 9.23 A
Ip rms : 0.423 A
iS rms : 3.84 A
Core : ee 25/13/7
Np : 71 turns
NS : 8 turns
Nd : 10 turns
Offline jonpaul
Re: Choosing copper wire thickness
« Reply #1 on: March 13, 2023, 11:50:39 am »
What is the Vp-s eg mains?
What insulation required?
EMI/safety compliance?
Use wire tables, and Magnetics Designer if you have it.
See websites of litz mfg like MWS and Rubidoux for HF /skin/prox effect tables and charts..
Jon
Jean-Paul  the Internet Dinosaur
Offline Kokoriantz
  • Country: vn
« Reply #2 on: March 13, 2023, 03:13:56 pm »
Use the AWG table.
The primary is wire No 25. The secondary must be Litz wire or multiple No 25.
Offline jonpaul
« Reply #3 on: March 13, 2023, 06:24:44 pm »
The wire tables are not specific (usually!) for HF use/skin effect nor transformers with Trise, hotspots.
see excellent app notes and tables from MWS, Belden wire, etc.
Jon
Offline Kokoriantz
  • Country: vn
« Reply #4 on: March 13, 2023, 07:19:26 pm »
It is specific with skin effect. No25 is suitable up to 85khz, says the table. For the secondary....?
  • Country: in
« Reply #5 on: March 14, 2023, 06:53:14 am »
Hi do i need to choose wire thickness and number of wires needed in parallel based on rms current rating or peak current rating.
Yes gauge 25 is rated for 85KHz thus it can be used for the primary my concern is when it comes to wire thickness do i need to consider rms current or peak current please tell me apart from the skin effect.
Offline jonpaul
