Author Topic: Spice to Simulink?  (Read 3241 times)
Offline AgrumTopic starter
Spice to Simulink?
« on: May 29, 2020, 04:18:39 pm »
Hello,
I hope that I'm in the right section.
I would like to know if there is a simple way to transform a LTspice model into Simulink.
I'm very new to Simulink.
Thanks
Offline Mj12
Re: Spice to Simulink?
« Reply #1 on: May 29, 2020, 08:56:13 pm »
There seems to be way to convert SPICE to simulink
https://se.mathworks.com/help/physmod/sps/ug/converting-a-spice-netlist-to-simscape-blocks.html
But if you are talking ltspice macromodels (IC:s and stuff) you are likely out of luck
I would recommend to look into component datasheet and device block diagram and recreate relevant parts in simulink. Not "simple" but not exceedingly hard either
Offline jbb
« Reply #2 on: May 30, 2020, 01:32:09 am »
It depends a lot on what you're trying to do.  For power SimPowerSystems or PLECS are quite good.
For signal analysis, I'm not really sure.  The 'typical' Simulink approach would be to model the parts (likely in reduced detail) with Simulink blocks.
Offline ahbushnell
« Reply #3 on: May 30, 2020, 11:58:44 pm »
I use PLECS all the time.  They have models for power electronic components.  You can even include C programing in blocks.  Also does thermal and magnetic simulation as components.
Andy
