Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Splice in the USB cable
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Splice in the USB cable (Read 1105 times)
IconicPCB
Super Contributor
Country:
on:
October 15, 2019, 02:32:18 am »
How troublesome can a splice in USB2 be?
Logged
IconicPCB
Super Contributor
Country:
Re: Splice in the USB cable
Reply #1 on:
October 15, 2019, 02:38:55 am »
I am not sure how to determine the requirement.
A USB 2 camera lives on the cable. It plugs directly into the PC.
The cable looks like it had been either cut inadvertently and repaired or extended by 15 cm.
In use the camera ( part of machine vision openCV ) is showing some instability in the form of flickering display where the flicker appears as change in size of displayed item.
Logged
Monkeh
Super Contributor
Country:
Reply #2 on:
October 15, 2019, 02:44:16 am »
Quote from: IconicPCB on October 15, 2019, 02:32:18 am
Very.
Replace it.
Logged
NiHaoMike
Super Contributor
Country:
"Don't turn it on - Take it apart!"
Reply #3 on:
October 15, 2019, 03:24:01 am »
Cut out the splice and replace it with a cheap hub as a repeater.
Logged
Pack34
Frequent Contributor
Reply #4 on:
October 16, 2019, 10:26:43 pm »
It could be if you're sending a lot of data. I've had some pretty dodgy splices on some USB-FS and USB-HS cabling and they worked fine. That being said, if you're noticing some odd behavior then I would replace it. Long runs of USB2 cables are pretty cheap.
Logged
IconicPCB
Super Contributor
Country:
Reply #5 on:
October 16, 2019, 10:37:53 pm »
It, the USB cable, is the camera cable; partof machine vision setup.
Been experiencing some vision instability. Control processor has died now so need to repair the control processor and then address the USB cable issues.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
