Author Topic: Make your own battery pack - 50W output  (Read 645 times)
Offline axolotylTopic starter
« on: June 21, 2018, 06:52:58 pm »
We made caddies to hold LiPo batteries for your own battery pack, and are sharing the STL files.
The charger output is USB-A,  2.7A per port, 50W total.
Parts
- Charger: www.pirlcharger.com
- STL files: https://www.youmagine.com/designs/battery-caddy-for-the-pirl-charger
- LiPo in red caddy: ZIPPY Compact 1000mAh 3S 25C Lipo Pack
- LiPo in gray caddy: Turnigy 800mAh 3S 20C Lipo Pack (E-flight Compatible EFLB0995)
- Build details: https://www.kickstarter.com/projects/pirl/the-ultimate-charger-for-power-users/posts/2215614
We'll be adding more larger battery case designs on Youmagine.
