Author Topic: SSR and Holding Current  (Read 1251 times)
Offline kolbepTopic starter
    • ShoutingElectronics.com
« on: November 25, 2021, 07:03:40 pm »
Hi All.
Just a quick one.
I have several led string lights (230v 7w per 20m string) = 0.031mA
IIRC the strings have 160 leds in Series with a resistor, which is in parallel with another 60 leds with their resistor.
I am trying to run them with Omron G3MB-202P Solid State Relays (1 solid state relay per string). The SSR's are controlled with Shift Registers on an Arduino.
I am having a problem where the LED strings where they are running dim, sometimes don't light up, or light up, then go dim immediately afterwards
The Omron SSR's are rated for 0.1A to 2A current. I presume the 0.1A is the minimum (holding) current.
My Arduino program does not pulse the SSR's, instead it keeps the power on to the SSR the whole time the light chain is meant to be on (i.e any time from 250ms upwards). Does that mean that I do not need to worry about the 0.1A holding current (because the SSR does not need to self latch)?
If I need to worry about the holding current, then I will need to put a dummy load equivalent to 2300R, 23W (that will probably need to be normal lightbulbs, because large resistors will get a bit hot.
If it is not the Holding Current causing the problems, then could it be that I am trying to run the LED strings with a Triac (and as there is no rectifier, the LEDS are only drawing on the forward cycle). If that is the case, then I will probably need a bridge rectifier on each string.
It also seems to be more problems with the White-Flash Strings. They are similar construction, but every 5th LED flashes at it's own rate.
Thanks for any suggestions.
P
www.ShoutingElectronics.com Don't just talk about Electronics, SHOUT ABOUT IT! Electronics Blog Site and Youtube Channel
Offline NiHaoMike
    • Facebook Page
Re: SSR and Holding Current
« Reply #1 on: November 26, 2021, 01:31:42 am »
Try using a series combination of a resistor and capacitor as the minimum load, good starting point would be X rated 1uF and 100 ohm, 2W.
The following users thanked this post: kolbep
« Reply #2 on: November 26, 2021, 05:55:31 am »
Thanks,
Let me scrounge through my boards, and see if I can find some to try that out.
P
« Reply #3 on: November 27, 2021, 06:57:56 am »
Just another question,
the voltage for the 1uF Class X Capacitor,
What voltage should that be, with our Voltage in South Africa being RMS 240v or should it be based on  the peak of 340v?,
Offline NiHaoMike
    • Facebook Page
« Reply #4 on: November 27, 2021, 12:46:31 pm »
Every X rated capacitor I have seen is rated to at least 250V RMS, that's a nominal rating and will work on 240V.
« Reply #5 on: November 27, 2021, 01:03:46 pm »
Thanks,
Will give it a shot
« Reply #6 on: January 01, 2022, 03:49:36 pm »
Well, it Worked.
Thanks NiHaoMike
Here is the project in its huge glory
https://youtu.be/_u6RM6NwyWw
