It's my aim at getting close to their max switching frequency specification. I understand that there is no way they are ever going to utilize it at 100 Hz, nor can an SSR handle 100Hz smoothly, but I'm absolutely sure a mechanical relay would not be able to handle 100 Hz! I think most of the issue here is customers making requirements documents without having a proper sitdown beforehand. I just talked them into dropping the 3A requirement which would have been used to drive some solenoids in favor of external interposer relays, so I think I'll consider the issue solved. However, if you have any insight on SSR AC/DC architecture it would be much appreciated from a more intellectual frame of reference.
