Can't you just disable the address decoder so it stops asserting the chip enables for the RAM ICs?
I designed a 2MB RAM expansion card for an old computer which is powered by a 486SLC CPU (QFP100 package).
Can you show us a complete schematic of this RAM expansion card? Does it insert into a standard interface on the PC motherboard? What's the model/name of this PC and interface?
Sorry for late reply.They are 4Mbit parallel RAMs :https://www.mouser.it/ProductDetail/913-AS6C4008-55SINIIRC I already tried the disable the /CE lines and additional RAM was still recognized by the system.Attached are schematics.
Quote from: caius on April 28, 2023, 09:28:39 amSorry for late reply.They are 4Mbit parallel RAMs :https://www.mouser.it/ProductDetail/913-AS6C4008-55SINIIRC I already tried the disable the /CE lines and additional RAM was still recognized by the system.Attached are schematics.If the /CE is pulled high, the data pins will be high-Z and it won't respond to WE / OE controls. If that isn't working, it means that either you haven't actually disconnected and pulled high the /CE pin, or the motherboard is using some other sense mechanism to detect the expansion card rather than the RAM chips themselves. This could be (for instance) in presence detect pins that are shorted to Vdd or GND right at the 80 pin connector, or even the connector itself having a physical presence switch similar to how TRS and DC barrel jacks often work.Can you describe what happens when the "additional RAM is still recognized"? Does POST fail because it detects memory that is disabled?
