I am currently trying to design an enclosure and PCB for a data logger. The problem is i need to be able to insert and remove the micro SD card through the side of the enclosure, ie. without opening the enclosure. I am a bit stuck for ideas for this issue. Any suggestions?
Thanks in advance
