Hi All
I want to make and switch to control light in cabinet. I need to switch 220 VAC with triac and reed switch. I will place a magnet to door and I will place main box across magnet. The maximum lenght is 15 cm between door and main box. I think reed switch will work properly.
You know reed switchs are normally open and when magnet is getting closer, reed switch will close. Could you help me to build schematics with NO reed switch ?
