My latest purchase is a switching adjustable bench power supply 3-15 Volt 25 Amps, branded as Teleconcepts
, the real manufacturer is Manson modeled SPS-8250.
Its quite similar to Dave's bench psu Manson 9400 40A 3-15V (branded as Powertech) in his tear down video EEVblog #272, though mine has lower power and has different layout as Dave's uses bigger transformers/inductors.
Everything works perfectly, its just I want to replace the noisy & crappy sleeve bearing 8 cm fan with much better quality fan like Sanyo Denki which I own.
Inside the psu, I noticed there are so many types of glues used, and for sure they're not saving pennies like using only one type of glue for all.
I guess its a good thing, but is it necessary to use different glue for different types of objects ?
Like why don't they just use the white one for the big electrolytic caps ?
Examples ...
The white one used in inductors or capacitors, while the dirty yucky brown type at two big Capxon caps...
.. or the plastic case feets which is the same brown type as above for holding the Capxon caps...
... or hot glue for securing the main on/off switch to the plastic front panel....
... or red ones for all screws holding the pcb, and also the nuts for the two big main output banana connectors ...
