I have configured a well known TL071 opamp in single supply and AC coupled inverting amplifier. with 10K and 1M resistors, it produces around 100x gain.
I inject a 10mV sinewave signal to the input. for the 10mV signal, I should get around 1V after amplification, it is almost okay, but look at that weird instability (the video has attached). The frequency is just 300Hz and if I increase it, this instability would be stronger.
The supply is regulated. oscilloscope has no noise. The signal generator is the Siglent brand and no noise.
I have tested the circuit also with a battery but the same results. with this setting, The GBW is about 300 * 100 = 30Khz, which is far away beyond opamp limits, but why this happens?
Has anybody experienced this? is this a fake opamp?
