Hi
That title is very contradictory I know
I have a product which I am soon'ish making 1000 of.
https://www.nextpcb.com/ is the PCBA house, and they already all sorts of automatic testing both on the PCB and on the soldered components. But I thought it would be nice to have a quick (=cheap) "manual" test of the assembled boards, since I intend to send the products directly to the end customers.
All I need is to make a test device that I can easily "plug" in the board to test it, then that device can have a "test" button that will do all I need - that way it's only a few seconds testing per board.
My problem is the "plug" part - the board has two female TRS connectors, two DIN-5 connectors, and a USB type-B connector, so either my test device has 5 cables but that will take forever to plug and unplug, or it could have one big "bar" where all the connectors are together so they can be plugged in at the same time - but that sounds dodgy and the "bar" of male connectors has to be strong enough to endure 1000 plugging+unplugging.
So I was thinking routing PCB traces from the connector pins to a IDC-like connector on the board that can be easily accessed. Then the soldering of the actual connectors will not be tested but it's through hole so the chance of them not being soldered correctly is pretty low I think.
I understand having a panel connector would be the best (I have seen this
) but I have no experience in doing panels and I left that job to the PCBA house, so I am thinking for now testing it per board.
What do you guys think? Am I on the wrong track all together to automate final testing? If not, which connector should I aim for?
Thank you!
Simon
