If you look closely at the symbols for Th1 & Th2 you'll see an extra tick on the gate terminal. I believe these are GTO (gate turn off) thyristors that are used in older inverters and motor drives. These devices can be shut off and so don't need something else for commutation.
Sometimes thyristors are triggered on by a short, fast voltage spike, ie A-K dV/dt can induce enough current that, with leakage current, is enough to trigger the device. Since the gate current isn't fast and high enough to snap the device on, it turns on slowly and may cause local hot spots that can damage it. Thyristors can also be damaged by too much current, which can be caused by the transformer core saturating, the anode current quickly rising and then not being shut off in time to prevent damage. It can also be caused by a secondary overload as the only thing limiting a current in a transformer is the series resistance of the windings.
At a race recently I bumped into a fellow that was in charge of the electrical system for one of our Rapd Transit lines. One thing he said was that track voltage was about 750 VDC. Would this inverter be for some sort of traction equipment?
