A TL494 or similar and toroid or bobbin core transformer is relatively simple to build and understandIts often used in car amps to get quite a bit of power at reasonable efficiency without being too expensive.
Quote from: Psi on January 27, 2015, 09:47:45 amA TL494 or similar and toroid or bobbin core transformer is relatively simple to build and understandIts often used in car amps to get quite a bit of power at reasonable efficiency without being too expensive.Simple, maybe. That doesn't mean it's right.Even the cheapest Chinese crap PSU doesn't get away with that, because 1. they're dealing with real live mains, and 2. the output has to be regulated.Tim
is flyback ok @ 180W Power Output?
