Author Topic: Stepper motor too hot  (Read 4367 times)
Offline metRo_Topic starter
  • Country: pt
« on: November 03, 2013, 05:07:59 pm »
I'm using the following stepper motor Bipolar, 200 Steps/Rev, 20×30mm, 3.9V, 0.6 A/Phase with a A4988 Stepper Motor Driver.
After some minutes it get too hot. So hot that It boils a water drop :s
The power source is 9v, measured with the multimeter it is comsuming 600mA/700mA (limited on the driver).
It is normal that it gets to hot?
Thank you
Offline nickm
Re: Stepper motor too hot
« Reply #1 on: November 03, 2013, 06:02:50 pm »
No. A lot of stepper drivers have a way to adjust the current provided to the motors which will.  The motor driver page you linked has a section on current limiting.  Try reducing the current limit and that will reduce the power dissipation.
  • Country: pt
« Reply #2 on: November 03, 2013, 06:10:45 pm »
I limited it to 600mA, if I reduce it more it doesn'h has enought torque for my application. I'm +- inside the parameters, I expect it to be hot but not too hot.
Offline Zbig
« Reply #3 on: November 03, 2013, 06:58:35 pm »
Dude, haven't you missed the 3.9V vs. 9V part? You're pumping almost 2.5 times the rated power through that motor.
EDIT:
Ah, only now I read you did limit the current...
« Last Edit: November 03, 2013, 07:37:02 pm by Zbig »
Offline Rufus
« Reply #4 on: November 03, 2013, 09:27:16 pm »
It is a switch mode driver so the supply current is not same as the motor coil current.
The motor is specified with a +80C temperature rise at the rated current, and that probably assumes some heat sinking from the motor mounts. The specification is telling you it will run above 100C.
Offline Alex
« Reply #5 on: November 03, 2013, 10:12:32 pm »
The higher the voltage you run the motor, the higher the rate of rise of the current through the windings.
The integrated PWM current regulator might have a minimum on time. Also, the current limiter will have an associated delay to it, so you should not rely on current limiting to tame the PWM regulator. In other words, I suspect your RMS current through the motor, coupled with the high supply voltage causes excessive power dissipation.
Try using a motor with higher winding inductance - usually more turns and higher voltage. That will also increase your torque and reduce your current drain.
Alex
Online amyk
« Reply #6 on: November 04, 2013, 06:29:52 am »
I've seen stepper motors in office equipment (big faxes, copiers) with big red "HOT!" stickers on them --- they do get over 100C easily and keep working. Some of them have forced cooling via fans too.
Edit: your stepper has class B insulation good for up to 130C.
« Last Edit: November 04, 2013, 06:31:39 am by amyk »
Offline george graves
« Reply #7 on: November 04, 2013, 08:23:40 am »
If you need cooling for your steppers, you might look at what the reprap 3d printer guys are using.  NEMA 17 is mainly what the reprap guys use - so if you're using 17's you might be in luck - there are some cheap options now-a-days.
Offline poorchava
  • Troll Cave Electronics!
« Reply #8 on: November 04, 2013, 08:35:41 am »
Steppers may get hot. the ones that I have in my CNC machine were about 70...80 deg.C when running at 1.7A driven by TB6560.
