Author Topic: Spot the datasheet error  (Read 6866 times)
Offline TerminalJack505Topic starter
« on: May 31, 2013, 01:55:32 am »
This schematic is an application from the TLC3702 datasheet.  The TLC3702 is a dual comparator with push-pull outputs.
There is an error that prevents the circuit from working as intended.  Can you spot the error?
Offline Rufus
Re: Spot the datasheet error
« Reply #1 on: May 31, 2013, 02:13:03 am »
It depends what the prizes are....
« Reply #2 on: May 31, 2013, 02:15:14 am »
The prize for the first correct answer is:
Bragging Rights!
Does a nerd need anything more?
Offline Rufus
« Reply #3 on: May 31, 2013, 02:21:05 am »
I'll pass. It is just a dumb mistake. I would criticize it more for crappy arrangement of the oscillator components.
Offline smashedProton
« Reply #4 on: May 31, 2013, 05:42:27 am »
Please don't make fun of me if I'm wrong... I'm a beginner.
The input signal is going into the wrong terminal on the left.  It should be on the positive
Invention, my dear friends, is 93% perspiration, 6% electricity, 4% evaporation, and 2% butterscotch ripple.
« Reply #5 on: May 31, 2013, 05:43:59 am »
Oh, :palm:  both drive amps are coherent.
« Reply #6 on: May 31, 2013, 05:46:46 am »
Nope...   what is the error?
Offline c4757p
  • adieu
« Reply #7 on: May 31, 2013, 05:50:46 am »
Ooh! Ooh! I know! Pick me!
They let monkeys draw the left half of the schematic!
(C'mon, it's an easy one. Look closely. Attention to detail, people!)
Different part numbers; I'd assume one responds inversely.  (Couldn't find a datasheet to confirm.) That isn't wrong.
« Reply #8 on: May 31, 2013, 05:52:03 am »
Correct.  Yay!  Bragging rights go to smashedProton.
Don't worry.  I didn't spot it right away.  In fact I have the part and was going to build an oscillator with it and noticed the one in the datasheet so I tried to simulate it and it didn't work.  I then built it on a breadboard and it still didn't work.
I guess I just put too much trust in the guys writing and proof-reading the datasheet.  You would think they would know their stuff.
Offline c4757p
  • adieu
« Reply #9 on: May 31, 2013, 05:54:20 am »
Now wait just a gosh darned minute. I want bragging rights too.
"1/2 TLC3704"? I don't think so... TLC3702!
« Reply #10 on: May 31, 2013, 05:54:43 am »
You get a runner's-up prize for spotting the different part numbers.  Not sure what happened there.
Offline c4757p
  • adieu
« Reply #11 on: May 31, 2013, 05:59:26 am »
   :D That's not even what I was talking about in that quote! I meant the SN75603/4 - spent quite a while looking for the datasheet for that... Still didn't find one - but I assume one is inverting.
They really ought to update those datasheets with a different part. The only references to that chip I could turn up, besides a few people selling them with no description of what they are, were in TI comparator datasheets... They've got to have another motor driver in their extensive catalog!
Offline HackedFridgeMagnet
« Reply #12 on: May 31, 2013, 06:37:30 am »
I don't really know but I am guessing the LHS doesn't oscillate.
« Reply #13 on: May 31, 2013, 06:59:18 am »
Yes, that's correct.  The two inputs are swapped and the comparator won't oscillate.  The oscillator portion of the schematic should look more something like the attached schematic.
