Here's an interesting design puzzle of a power supply:
Input: Up to 520V DC, 320-400V typical operating, minimum as low as practically attainable. Minimum startup voltage should also be as low as practically attainable.
Output: CVCC 9-12V or 12-16V for charging 3S or 4S battery, maximum current up to 20-30A if input voltage 300V or higher, below that output current drops accordingly. Both voltage and current limits would be programmable by external controller.
Efficiency: 85% or better when input voltage in typical operating range and output current is 4A or more up to 80% of maximum.
Other considerations: If input power is insufficient for sustained operation, repeated startup attempts must not damage supply.
The application is an auxiliary power supply for a solar power control system. I'm thinking it would make sense to modify an ATX PSU (with active PFC) for that application, but extending the maximum input voltage to 520V seems a bit problematic.
