Author Topic: STP1612PW05 LED driver  (Read 386 times)
Offline alizare368Topic starter
« on: June 19, 2019, 12:41:52 pm »
Hi
 I used these codes to run the RGB LED DRIVER(stp1612pw05), but it does not work.
the PWCLK is 2M.
 #define SPI_SCLK_LOW_TIME  200
 #define SPI_SCLK_HIGH_TIME 1
uint16_t SPI_1(uint16_t byte_out)
  uint16_t byte_in =0;
  uint16_t bit;
for(i=0;i<16;i++)
        //LE pin is low
HAL_GPIO_WritePin(GPIOB,GPIO_PIN_9,GPIO_PIN_RESET);
for (bit = 0x8000; bit; bit >>= 1)
/* Shift-out a bit to the MOSI line */
HAL_GPIO_WritePin(GPIOB,GPIO_PIN_4,(byte_out & bit) ? GPIO_PIN_SET : GPIO_PIN_RESET);
/* Delay for at least the peer's setup time */
for(int i=0;i<SPI_SCLK_LOW_TIME;i++)
/* Pull the clock line high */
HAL_GPIO_WritePin(GPIOB,GPIO_PIN_5,GPIO_PIN_SET);
// /* Shift-in a bit from the MISO line */
// if(HAL_GPIO_ReadPin(GPIOC,GPIO_PIN_8)==1)
// byte_in |= bit;
/* Delay for at least the peer's hold time */
for(int i=0;i<SPI_SCLK_HIGH_TIME;i++)
/* Pull the clock line low */
HAL_GPIO_WritePin(GPIOB,GPIO_PIN_5,GPIO_PIN_RESET);
        //LE pin is high
HAL_GPIO_WritePin(GPIOB,GPIO_PIN_9,GPIO_PIN_SET);
HAL_Delay(1);
//return byte_in;
while (1)
    SPI_1(0xffff);
