I'm using an MSP430F5172 uC and reading a battery voltage at 500ms intervals. Here's the circuit below for sampling the battery voltage:
When EN_VBATT_READ goes high, the voltage divider is active. The divider divides down at a ratio of 1:0.7848 so that a max input voltage from VBATT = 3.2V results in an output voltage of ~2.5V at VBATT_DIV. The MSP430 is set up with a VREF=2.5V so 3.2V input gives full scale 10-bit output of 0x3FFF. When EN_VBATT_READ goes low, the divider is off, no current is consumed.
Cap C32 is there to act as a LPF but also to help hold up the voltage during the ADC sampling time. The relatively low values of the resistors in the divider allow me to achieve a low input impedance to the ADC.
At VBATT input voltages between 3.2V ~ 2.1V, the ADC readings are spot on, within 1 or 2 counts. Nice. The scope shot below shows the resistive divider turning on ( YELLOW trace is VBATT_DIV ). There is a delay for settling on C32 to charge up; then the green trace goes high ( start of ADC conversion ), then the green trace goes low ( end of ADC conversion )
As VBATT input goes lower, the VBATT_DIV waveforms gets weird. By weird I mean it doesn't reach the steady-state value I expect, and when the conversion is complete, there is a little hump. VBATT input for the scope shot below is 2.0V:
And at 1.9V, the VBATT_DIV waveform is not stable at all and has a big dip:
The end result is the low end of VBATT input voltage reads are far off from what is expected. My guess is that the ADC is loading the analog input pin more than I expected. Datasheet states ADC input impedance is anywhere from 36k to 96k & 3.5pF, which is much higher than the ~887 ohm impedance of the divider. So I don't see how this could be the case.
Also, I don't understand why this effect wouldn't be seen for higher input voltages too. I've tried all combinations of sampling time and conversion clock...in the end it doesn't really matter. Lower input voltages also give this bumpy waveform in the VBATT_DIV analog input pin.
Any ideas what might be the matter?
