From your png, I can see that you do not have a capture enabled.
>Setup
In settings, > "Interface" will drop down to show the available ones.
Use alsamixer or amixer to help if you have a lot of them.
I use Driver: alsa Rate 48000 frames 1024 periods 2
>Options # add the cmds
"Check Exe script on startup" : pulseaudio -k
"Check Exe script after startup": pacmd load-module module-jack-source channels=2; pacmd load-module module-jack-sink channels=2;
Everything else at defaults
Now save that setup in settings "My_pch_capture", you can make one file for each capture sound card
#It was difficult for me to realize that the whole jackctl seems to be able to only run on the one capture interface.
#It is not able to handle more than one stereo channeI have not tried 2 instances of jackctl yet.
"My_pch_capture" is exe when you select it and >apply >OK
When that is successful, the capture interface will appear on left side of the GUI, so you can pull cables from it to jaaa.
To pull a cable.
left click on a green output terminal -it will turn blue.
Hold left click then pull the blue cable, it will snake after your mouse as you pull it to the input terminal.
If all is good, the blue cable will turn green.
As I mention jaaa outputs do not work, so pull more cables from input to system playback
