If I use the transformers primary windings in parallel, I will get the secondary voltage I need easily. And the secondary current by the bucket load. But these transformers run very close to 100°C and probably higher if I monitored them powered up in parallel for longer. 40 minutes no load each in parallel get them up to silly temperatures, and I had 140mm pc fan above them. Looking at the original microwave oven front panel, the appliance doesn't have longer cooking times beyond 1 hour in timer settings. Ok so you could restart the over timer and continue cooking, but I believe at 1 hours cooking is right at the limits of the ovens use. I've cooked in these for up to an hour (varied cooking powers) But I'm certain I can detect a faint odour of transformer windings insulation smell. I doubt it's dangerous, but it's running flat out.
The no load primary power drawn from two transformers wired in parallel is around 6 Amps at 240 Volts, that's just crazy for long term use. I already had one transformer from a magnetron failure some years earlier, then a second oven failed in much the same way. So I decided to try running these transformers in series to see what they can output safely. The pair of transformers run fine with half the input voltage, so that's great for the primary windings longevity. But any secondary windings suffer from lack of power probably as already mentioned down to the poorer mutual inductance with half the input voltage per transformer. I'm trying to get enough voltage AC secondary to power an LM2940-12 and 4 X TIP36C pass transistors to achieve 12.00 Volts and a maximum current of 15 Amps at approximately 50 % duty cycle to drive a HF linear amplifier. I don't know if it's possible to get this voltage and power from these transformers. But I haven't exusted all options just yet. I'm only a hobbyist, and some of the crazy ideas I come up with have taken weeks of thinking to find a way forward. It might be that I have to abandon this idea eventually, but that won't be before I've tried all possible safe options. I'm sure I was a mad scientist in a previous life. I have even considered boosting the voltage with a boost converter then taking that voltage and putting it back through a linear regulator circuit. It's probably not even doable, but I wouldn't disregard any idea until I've gone over that idea at least once. I appreciate all the help and suggestions, but I'm not ready to quit yet.
