Hello,
I'm working on a DIY power supply project and I'm stuck with a problem since long time ago now.
The issue is that I want to display the output voltage and current of the power supply. To do that, I use 2 LCD panel meters.
Currently I'm using these ones:
http://www.circuitspecialists.com/pm-128e-backlit.htmlThese panel meters can be configured in 5Vdc with common ground. This is the option I chose, although I also tested them with 9Vdc isolated power supply.
In any case I use isolated power supply, so in practice there is should be no problem with any common ground.
Both panels are powered in parallel and connected following the schematic below.
In this configuration, LCD2 is not displaying correct measurement. However, if I disconnect LCD1, LCD2 works fine (when standalone).
From this schematic, it can be seen the Vin- of LCD1 is directly connected to the Vin+ of LCD2. My best guess is that LCD2 does not appretiate this for some reason.
How should I proceed, keeping in mind that I would like to avoid to power both panel meters with 2 separate power supply?
I understood that, when using panel meters that don't accept the comm on ground, the Vin- is somehow linked to the V+ of the power supply. Is there something similar in a common ground configuration?
Any suggestion will be appretiated.
