I want just go back and thanks for everyones suggestions. Today I finished and tested the design with the Max9924 (the uMax 10 is not the easiest to solder) and it works just beautifully. I wanted to test all approaches suggested, but now it impressed me so much that I will keep this design. I will test all others, but just when I will be bored and be curious just to see how they works. But definitely for everyone else in similar situation, the Max 9924 is very good choice to go, I used the reference design for A2 mode.
