Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Potting inside of the Wall plug Power Supplies
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Potting inside of the Wall plug Power Supplies (Read 340 times)
elefurtronik
Regular Contributor
Country:
on:
April 18, 2023, 01:24:36 pm »
Hello,
Is it logic to add potting inside of the wall plug power supply if it is working in a humid area? Do I see any issue if I add potting material on the circuit?
Logged
jpanhalt
Super Contributor
Country:
Re: Potting inside of the Wall plug Power Supplies
Reply #1 on:
April 18, 2023, 02:33:48 pm »
Potting can decrease thermal conductivity between the circuit elements and room air. Your circuit would run hotter. Since wall warts are designed to be as cheap as possible, there may not be much thermal margin. There are non-electrically conductive and highly heat conductive materials (e.g., epoxy-BN mixtures), but I would probably just insure everything was well protected with conformal coating. For BN-epoxy, see example here:
https://www.mdpi.com/2073-4360/11/4/597/pdf
Logged
elefurtronik
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
