Lots of good ideas. Mikejr, I'm struggling to see how that would work any better than what I've got with a capacitor in terms of reducing oscillations (I haven't been into electronics long, so I might be missing something obvious). David Hess, what do you mean by an 18V buck/boost? I'm trying to regulate the PV input not the output. NiHaoMike, I'm sure limiting the duty cycle would be achievable with a few extra components, but I'm still not sure that it will keep the input voltage constant. An MPPT would be best, but my micro is already pretty busy (both PWM channels are in use) and I'm not concerned about performance (this is a fairly small project). Seekonk, I'm struggling to visualize this circuit; could you please clarify?
I've started designing the PCB for this, so I'd rather stick with what I've got if possible (even if it sacrifices efficiency), so can anyone confirm whether or not my current circuit will function as expected?
