Hi Reg,
Thanks for your detailed reply. There are certainly many possibilities, both for sensing and for readout.
Regarded a suspended aluminium cylinder, one possible complication concerns the mechanical "stops" which prevent the cylinder from hitting the capacitive sensing pads or frame. If these are "hard" then each impact will deform both the cylinder and the pads, changing their shape and hence their capacitance and the balance. If they are "soft" then they will also be deformed by impact. This won't change the shape/balance of the pendulum but by changing the distance to the pendulum, it will also influence its capacitance. The fluid bubble sidesteps some of these issues, although as the discussion here has shown, it is not free of hysteresis.
A second issue is the orientation. I am not sure if it is correct to assume that a single wire will return the cylinder to the same orientation, particularly if that wire is very thin. (Even if the cylinder is round to 2.5 microns, that may not be good enough, as we are sensing significantly smaller motions.) The time constant for this might also be very large. And if you suspend the cylinder from multiple wires, that creates other potential issues.
For the record, I wanted to clarify one point:
As I understand, the TalyVel uses the suspension wires for signal as well.
This is incorrect. The Talyvel armature is suspended from five BeCu wires. One is a single strand, and the other four form two "V"s. All five of those (conductive) wires are attached to the internal metal frame of the device at the top end, and to the metal armature at the bottom end. While it is not their primary purpose, they do provide a conductive path between the moving armature and the fixed frame.
The sensing is done via two coils, located on either side of the suspended armature. The inductance of these coils is a function of their separation from the (steel) armature. The wires from each of these coils are entirely independent from the suspension wires, and are connected to the readout via a shielded set of twisted pairs. The two coils are part of a classic bridge circuit, driven by a 3kHz oscillator.
Cheers,
Bruce
PS: for the NASA/spirit vial design I would be grateful for guidance about the size/shape of the two top electrodes. For my PIE vial, the total internal length is about 95mm (3 3/4") and the bubble (when centered) has a length of about 32mm (1 1/8"). The NASA document suggests a rectangular electrode with a length comparable to the bubble, but if I do that, then the capacitance difference will not be a monotonic function of the displacement angle from horizontal. This is because, as the displacement increases from zero, the bubble first moves completely under one electrode (decreasing its capacitance) but then exits the electrode at the far end, increasing its capacitance again. If I make the electrode the same length as the bubble, then the capacitance will be a (roughly) linear function only for a total displacement of +- 16mm from the central position, corresponding to (nominally) +- 24 arcsec.
PPS: a second technical question. Are the CA3039 "diodes" just Si NPN transistors with the base and collector tied together? If so, can I just use (say) a transistor array such as CA3127 for this? If I understand correctly, the matching is desirable so that the offset voltages and junction capacitances are the same (as a function of temperature & forward current, and temperature & reverse voltage respectively). Is that correct?
