Author Topic: RPi On/Off Switch  (Read 1551 times)
Offline jwhitmoreTopic starter
  • Software head strays into the Hardware.
RPi On/Off Switch
« on: January 31, 2016, 06:10:52 pm »
I found this page out there with a design for an on/off switch for the Raspberry Pi. The circuit is for 5V power supply but I'm going to use it for 12V. I'll have a step down from 12V to the 5V but the 5V in the circuit pictured isn't going to get to an RPi I/O Pin so my using it for 12V should not cause a problem.
http://www.raspberry-pi-geek.com/Archive/2013/01/Adding-an-On-Off-switch-to-your-Raspberry-Pi/%28offset%29/2
Offline Paul Price
Re: RPi On/Off Switch
« Reply #1 on: January 31, 2016, 06:15:39 pm »
A much simpler way to completely shut off all power can be accomplished using a simple BJT or P-Chan MOSFET latching circuit, no relays involved.
Offline kb0thn
    • APRS World, LLC
« Reply #2 on: February 02, 2016, 12:49:59 pm »
We use AP2411S-13. It's a cheap little IC that is a high side switch and over current protection. Works great.
« Reply #3 on: February 02, 2016, 04:20:36 pm »
Thanks for both of those ideas both of which are much better then a relay. I'll look at both. A single chip high side switch sounds great but I'll have a P channel in my kit bag I can use.
