Author Topic: Cheap "jellybean" buck regulator  (Read 10995 times)
Offline LukeWTopic starter
« on: May 08, 2015, 08:18:18 am »
What would you recommend as a general-purpose, moderately low-power, low-cost regulator IC operating in a buck (or other step-down) topology?
Traditionally I'd use an abundant and cheap MC34063, but are there any better, more modern replacements that retain its low cost?
Typical use-case I'd be looking at: Vi=24V, Vo=5V, Io=500mA.
Being able to take the output current higher than that (say an amp, or two), and the input voltage higher than that (say somewhere 36-50V) would be nice but not critical.
Availability from the major Western distributors in small quantities is a plus, as is minimal size of external components, BOM cost and ease of inductor/diode/etc selection.
Offline mariush
Re: Cheap "jellybean" buck regulator
« Reply #1 on: May 08, 2015, 08:57:18 am »
Have a look at MCP16301, not quite cheap as a jellybean but you're saving money as you can go with smaller inductors and ceramic capacitors instead of large electrolytics:  http://uk.farnell.com/microchip/mcp16301t-i-chy/ic-dc-dc-converter/dp/2445581  (600mA max)
MCP16312 seems worth a look as well : http://uk.farnell.com/microchip/mcp16312-e-ms/dc-dc-switching-reg-buck-500khz/dp/2414135  (up to 1A)
AP5004 is cheaper and also works, but as it works at lower frequencies there's tradeoff in component sizes : http://uk.farnell.com/diodes-inc/ap5004sg-13/ic-buck-reg-so8/dp/1825352  (up to 2.5A)
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: May 08, 2015, 09:02:46 am »
The main thing about more modern regs is they run a much higher frequency so you can use cheap ceramic caps instead of electrolytics and small inductors.
MCP16301 isn't bad but there are cheaper options - look at Richtek and Alpha Omega at Digikey.
Choice reduces as you get to 24V in but still a few options
e.g. AOZ1280 ( which happens to have the same footprint as MCP16301)
http://www.digikey.co.uk/product-detail/en/AOZ1280CI/785-1277-1-ND/2769845
Day Job: Mostly LEDs
Offline ajb
« Reply #3 on: May 08, 2015, 03:24:15 pm »
For higher input voltages, there's the LMR16006. It's more expensive than the other options, but still SOT6/600mA and takes up to 60V, and also same pinout as the MCP16301.
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« Reply #4 on: May 08, 2015, 04:09:37 pm »
MC34063.
Jellybean catch-all SMPS chip for any configuration for up to 1.5A, or with external switch transistor any current.
Offline langwadt
« Reply #5 on: May 08, 2015, 04:25:09 pm »
MC34063.
but it is ancient and dog slow so you'll need huge inductors and capacitors
in proto quantities it's hard to beat the price of something like this:
 http://www.ebay.co.uk/itm/261688896873
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #6 on: May 08, 2015, 04:30:55 pm »
MC34063.
In China sellers vendors Shenzhen sells grab bags of 20 MC34063 at US$1. Try beat this.
« Reply #7 on: May 08, 2015, 07:17:09 pm »
MC34063.
Has poor efficiency and needs big caps and inductors. A dinosaur.
Costs saved on caps and inductors may more than offset parts cost diferences
Offline paulie
« Reply #8 on: May 08, 2015, 07:37:27 pm »
Only needs big cap and coil for high current. 10 for a dollar on Ebay. With cheap 2 cent inductor and penny diode has no competition for lowest cost. Can't be beat when high output, low noise, and efficiency are not that important. Oddly no cheap modules though.
Offline codeboy2k
« Reply #9 on: May 09, 2015, 07:20:40 pm »
2 cent inductor?  link please.
EDIT: you're probably talking about axial leaded 1W inductors... I can see those at 3 cents maybe 2 cents each in large quantities of 100 or 200 ebay
EDIT2: I found these 50mA SMD 1812 inductors at qty 200 , which works out to 7 cents each. ebay
« Last Edit: May 09, 2015, 07:22:39 pm by codeboy2k »
Offline paulie
« Reply #10 on: May 09, 2015, 07:30:02 pm »
Actually I misspoke. Should have said "ONE cent inductors" because that's what I paid earlier this year on aliexpress (always a dollar or so cheaper than ebay due to fees). But search there is a pain so here's a quick link for some 2 cent Ebay dealies:
http://www.ebay.com/itm/281642082320?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
If you call couple hundered pcs of penny parts "large quantity" then maybe not taking this hobby seriously. I am worlds cheapest man but don't consider spending a buck or two more for a lifetime supply out of the question. I do get a kick out of the phrase "color wheel". Wondered for years until finding out it's the same as chinese word for "ring". LOL
ps. Aha... I see you have discovered the real world of global pricing. It's always a proud moment when Digi-key/Farnell fanboys emerge from their cocoon.
« Last Edit: May 09, 2015, 07:44:19 pm by paulie »
Offline mariush
« Reply #11 on: May 09, 2015, 08:17:19 pm »
While it may work for one-off or hobby projects, when it comes to mass produce something you might want to stick with using a distributor or a company that can guarantee delivery of the amount of parts you need, and the quality desired.
What's the point of ordering 200 inductors off aliexpress or alibaba or ebay when next week the seller may no longer have the same inductor in stock, or they're mailing you a similar part and argue the specs are close enough to the other so they're interchangeable?
I want to be able to select a part that I want and then also select a few alternate parts with the same footprint in case the one I really one can't be sourced or becomes expensive, and this is hard with sellers on aliexpress or whatever, you can't really be sure  (one that i really want for the project and the rest as fallback/alternatives) with the same footprint and know I
I want to have access to the datasheet for parts and to have the peace of mind that the parts i buy now or next month will be genuine (and the same) and conforming to specs so I'm fine with paying a bit more for parts.
With ICs like MC34063, yes, you can buy them from eBay for cheap but again, you don't know if they're genuine or they're just what left after some pcb assembly job was finished, or what was dropped by the chip shooters, or even worse maybe they're fakes made in some Chinese fab with minimal or no testing/quality control... or maybe they're recycled off things like ethernet hubs or switches.
Buy a bit more expensive regulator IC but you reduce pcb space and use smaller parts like inductors and ceramic capacitors... or buy cheapest regulator IC and use whatever parts will work
Offline technix
  • Country: cn
    • My Untitled Blog
« Reply #12 on: May 10, 2015, 01:22:41 am »
In the homeland of Aliexpress I just buy all my parts from Taobao (the domestic version of Aliexpress) and those Mouser or Digikey prices, which can be several times more expensive, are largely ignored.
Just for reference, my small stock of 1mH 1A inductors came at 5 U.S. cents each, grab bags of 20 at $1; $1 will also get you a few hundreds of 1N5819 Schottky rectifiers. PIC16F72 microcontrollers a are blown off at $0.25/each, I got a few ADR01B precision reference at $1.25/each, and used (aka already burnt in, less long term drift than new) LM399 precision Zener are sold at $2.5 a pop.
Offline Rick Law
« Reply #13 on: May 10, 2015, 01:57:54 am »
Since you want low cost, I suppose you don't mind the cheaper Chinese parts.  How about XL1509 from XLSemi.
3.3V, 5V, 12V and Adjustable version.
Up to 2A (internal cut off at 2A)
4.5V to 40V Input Voltage Range
http://www.xlsemi.com/datasheet/XL1509%20datasheet.pdf
I first encountered the XL1509-ADJ when my B3603 failed.  The B3603 is an LM2596 digital buck, but it uses the XL1509 to supplies the internal voltage running the controller.
I blew the (low-current) inductor on the XL1509 by shorting the output.  For a while, I was using my B3603 with an MC34063 powered buck for the unit's internal power supply.  So I had an opportunity to compare the XL1509 head to head with the MC34063.
I found the XL1509 has better line and load regulation, plus a better noise profile than the MC34063.
Rick
Offline kjs
« Reply #14 on: May 10, 2015, 04:52:54 am »
Stick with Mhz frequency expensive TPS/LTC devices provides several benefits:
1. Higher freq allows to use tiny LC, which cost more than the chip sometimes.
2. No post regulators needed, since for most cases (for me, audio engineer), the frequency I care is below 100kHz, so harmonics of Mhz won't hurt.
3. Even ripple matters, killing ripple with LC is much easier at higher frequency.
4. For me, board area is more expansive than anything. You'd better kill me if you expect me to put a 1mH inductor on board.
5. Lower fail rate. Mhz devices response to over current or other contingency situations much faster than low frequency counterparts.
6. Better control. If you are designing a 1$ chip, you have the luxury to put complicated compensations, controls and protections on chip. 10c chips simply don't have die area to do these.
7. Since switching frequency is higher, the error amp has also higher BW, so sub Mhz input/output noise rejection is better, which is super critical in my business.
8. et, al.
Bo
+1! These 1 to 2+MHz switchers are by far superior and at the end often cheaper and a lot smaller. Especially when noise is critical. I hate to place a bunch of L/C filters on a board to get rid of sub 200kHz spikes.
Offline con-f-use
  • Country: at
« Reply #15 on: May 10, 2015, 08:08:03 am »
The main thing about more modern regs is they run a much higher frequency so you can use cheap ceramic caps instead of electrolytics and small inductors. [...]
I have ordered a few of these but I'm a bit puzzled by one figure in the datasheet. There C3 is connected to nothing and has no value. By reading a little more carefully I found that a 10n capacitor (presumably C3) is to be connected between BST and LX pins. If someone used the AOZ1280 in that way, can you confirm that?
« Reply #16 on: May 10, 2015, 08:59:32 am »
Yes - it's a charge-pump cap for the MOSFET gate driver - MCP16301 has the same
« Reply #17 on: May 10, 2015, 09:02:11 am »
You can go high frequency without needing to use expensive parts from TI or very expensive from LT.
Richtek and AOS are my usual first places to look.
