Electronics => Projects, Designs, and Technical Stuff => Topic started by: sri2014 on June 11, 2020, 06:18:01 am
Title: Switching circuit with input clock
Post by: sri2014 on June 11, 2020, 06:18:01 am
i have attached the timing diagram. I want something similar to monostable multivibrator but with so additional features. don't know how the circuit will be.
Case 1:
I want the output to go high at the rising edge of the input, output stays high as long as the input is high but output will be pulled down after 500ms even if the input is high.
Case 2:
Output should go low if the input is less the 500ms, i.e. if the Input is of 300ms the output will also be of 300ms.
Title: Re: Switching circuit with input clock
Post by: SiliconWizard on June 11, 2020, 02:29:03 pm
If I get it right, what you want is basically some pulse width limiter.
One simple way of achieving this with discrete parts would be to just "AND" the output of a monostable with the input signal.
Post by: Benta on June 11, 2020, 05:32:03 pm
CD4538/MC14538 set up as edge triggered MMV, plus an AND gate at the output.
