This is fine. Presumably:
- You have a pull-down on PROT, and preferably a Schmitt trigger as well
- Assuming R1 is a low-value (shunt) resistor
- And R3 is some resistance to limit Q1 base current under fault conditions (say 1k, maybe lower like ~100R if PROT needs to carry a lot of current)
- And C1 is the incidental (bypass) capacitance of the load, which might also be switched on/off externally (not shown)
- And V1 is always on while monitoring is needed. Note that switching in a precharged C1 with V1 off (backflow condition) would violate this assumption, or a short circuit sufficient to cause V1 to collapse.
- Which further assumes V1 is a fairly good voltage source, as the ideal SPICE symbol might imply.
Then, R4 --> inf is likely fine, as R1 and R3 will provide adequate turn-off / discharge when below threshold. And delay can be introduced by simply capacitance in parallel with (or in place of) R4.
This is quite a list of assumptions, but they are pretty likely, and the application isn't particularly uncommon, if I understand the purpose correctly.
Which...
This seems like a classic XY problem.
Time is wasted discussing a proposed solution to a ill defined problem.
First define WHAT the problem is.
Then discuss HOW it might be solved.
...If the above assumptions prove incorrect, then this is spot on!
Which is to say: I feel the above assumptions are reasonable enough that, calling into question the overall purpose probably isn't needed; but, more information is always,
always welcome.
