I want to build a switching step-down circuit from 320 Vdc (rectified 230Vac) to half that. It would handle no more than about 250mA output. Output voltage does not need to be much stabilized with output current variations. As long as it stays within, say 120 and 180 V it should be OK
I would like to get some help completing the attached circuit. R1 represents the max load but the load can be anywhere from zero to max. I believe the value of L1 is not critical and I have many taken from PSUs
I believe as long as there is a minimum load a 50% switching duty cycle would maintain roughly a 50% output voltage and the circuit could work without feedback which would simplify things a lot.
- The main question is what control circuit circuit to use, with or without feedback. What frequency to use. The higher the frequency the higher the losses so I am guessing somewhere between 15 Khz and 40 Khz.
- What switching element to use. It needs to be fast switching and withstand 400V
- What fast diode
Edited to add: probably a crowbar at 190V at the output in case the switch fails closed.
