Author Topic: Switching pre regulator  (Read 1315 times)
Offline OM222OTopic starter
« on: July 23, 2020, 09:30:39 am »
I have always used just a battery and a LDO in applications where noise is inportant but obviously battery and LDO means really awful battery life and low effeciency overall.
I would like to implement a switching pre regulator , followed by a filter (ferrites and capacitors) and then the LDO. I have searched quite a bit on google but didn't find anything other than control the output of the regulator with something like a dac or digital pot but that's not ideal.
Is there a way to have the output of the LDO in the feedback loop of the pre regulator so adjusting the output of the LDO, automatically adjusts the switching regulator?
Offline Vovk_Z
  • Country: ua
Re: Switching pre regulator
« Reply #1 on: July 23, 2020, 12:24:31 pm »
Yes, look at  LT3080 datasheet, p.21, 'Adjustable High Efficiency Regulator'.
You need only a Mosfet, and that's it. You use resistive feedback divider circuit of a DC/DC 'prereg' as it is, and just add a Mosfet Drain-Sourse in parallel to this feedback divider of a DC/DC regulator, and gate with series resistor to the linear (LDO) regulator output.
I used this way to make a XL4016 as pre-regulator for LM350/LM338. Works fine.
« Last Edit: July 23, 2020, 12:31:50 pm by Vovk_Z »
Offline Vovk_Z
  • Country: ua
« Reply #2 on: July 23, 2020, 12:36:11 pm »
If I'm not wrong I used usual 2N7002 Mosfet, it gives about 2.5-4 V voltage drop. So for low-drop LDO regulator you may need some logic-level (low-level) Mosfet.
The following users thanked this post: OM222O
Offline hugo
« Reply #3 on: July 23, 2020, 03:58:58 pm »
TP0610 is a p channel mosfet and 2N7002 a n channel one ... you could be wrong  ;)
Offline Vovk_Z
  • Country: ua
« Reply #4 on: July 23, 2020, 04:17:52 pm »
Oh, yes. It was BSS92.
Offline David Hess
  • DavidH
« Reply #5 on: July 23, 2020, 11:31:56 pm »
Yes, that can be easily done.  However first I suggest reading the Linear Technology application notes written by Jim Williams about low noise switching regulators:
https://www.analog.com/media/en/technical-documentation/application-notes/an70.pdf
https://www.analog.com/media/en/technical-documentation/application-notes/an101f.pdf
https://www.analog.com/media/en/technical-documentation/application-notes/AN118fb.pdf
Offline Pawelr98
« Reply #6 on: July 24, 2020, 01:20:27 am »
Classy TL494 can do that because the error amplifiers can be tied to anything you want.
With a bootstrap circuit (just like the LT part has) and a proper driver it should be able to drive mosfet switch and provide decent efficiency.
Offline Marco
« Reply #7 on: July 24, 2020, 05:49:18 pm »
Why not a PNP to have a little easier to predict drop?
