I also received a XL-DC (Symmetricom branded) in the mail today, pictures and more info will follow later.
But I can tell you right now that it's a very basic unit, just a PSU and GPS board, 12 Symmetricom antenna, no other I/O, no Rb and no OCXO.
This leads to my question, is it possible to fit an OCXO even when there is no wire harness for it?
On the pictures in this topic I see that the power and coax go somewhere under the ribbon cable connecting the backplane and the front panel but it's not clear where they connect.
I'm also not sure if the option would need to be enabled in software.
I guess it's always a possibility to replace the TCXO on the GPS board with an OCXO or Rb?
Again, I will post picture and info according to the template later this week but I thought it was wise to ask this question first in case there is something in particular I need to look for that might not be included in the template
PS: The unit, as bare as it is, does function perfectly, 3d time fix in a few minutes and so far it seems within spec compared to my Rb optioned Oscilloquartz OSA 5230 receiver.
