So I'm working on a switching regulator using the LTC4162. It is a synchronous buck converter IC by linear/analog and it keeps failing and turning into a resistor of a few ohms after running nice and cool for a few minutes with a constant load. My guess is that ringing on the switch node is causing the primary switch to be pushed past it's Vds breakdown. I haven't rebuilt the circuit since I came up with this idea so I can't check the current through the inductor. If it turned out that the inductor did not have a current passing from the switch node I suppose the next possibility is that the low side switch has failed.
I cannot find the breakdown voltage of the internal power switched in the datasheet
https://www.mouser.co.uk/datasheet/2/609/LTC4162-L-1398190.pdf. The Absolute maximum ratings listed on page 3 and the electrical characteristics starting on page 4 are pretty light on info it seems for such a highly rated manufacturer. (annoying this sheet gives lots of general switching regulator design advice and of course masses of info about the digital telemetry system but does not specify the anything more than the Rds on for the power switches).
This means I cannot make a spice model of the internal power switches because one important parameter for simulating the ringing on the switch node when the primary/upper power switch/FET turns on is the output capacitance of the lower/secondary/rectification FET.
have been running the circuit with an Vin of 35v only one volt away from the Absolute max but this is clearly how it's designed to run and I check the bench supply using a meter.
Also I have done my best to clean the flux after soldering this WQFN package with out ultrasonic cleaning. I did not manage to specify the solder mask expansion as I wanted it so there is not solder mask between the pads for the IC pins but visual inspections and R measurement said no bridges.
I appreciate there are probably a lot of factors that could go into a failure mode like this but I thought I'd try to outline some of parameters of the design and make some of my own guesses about whats happening and see if more experienced people can offer at least some suggestions of what to try. This is my first serious switching converter design, speak slowly
BTW these ICs are pretty expensive for a hobbyist so I'm taking it easy and trying to get some good ideas of what might be causing this before ordering more and stressing myself out trying to solder the bl*?dy things.
Many thanks,
Han
