Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
LMX2582 sine or square wave output (RF Synthesizer with Integrated VCO)
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: LMX2582 sine or square wave output (RF Synthesizer with Integrated VCO) (Read 1499 times)
sorin
Frequent Contributor
Country:
on:
May 15, 2016, 03:47:37 pm »
Please can anyone tell me what output should have this Synthesizer, sinewave or squaewave?
Ther are 2 type of outputs, direct from VCO and the other from the counter output
Can we use this Ic as a signal generator?
Thanks in advance!
http://www.ti.com/product/lmx2582
Datasheet:
http://www.ti.com/lit/ds/symlink/lmx2582.pdf
Logged
danadak
Super Contributor
Country:
Reactor Operator SSN-583, Retired EE
Re: LMX2582 sine or square wave output (RF Synthesizer with Integrated VCO)
Reply #1 on:
May 15, 2016, 07:02:53 pm »
The output of the VCO is a squarewave, the counter out a pulse
with varying duty cycles depending on /n and fractional divider
logic.
If you want a Sine, Triangle, Saw, Square then a DDS chip more appropriate.
http://www.analog.com/en/products/rf-microwave/direct-digital-synthesis-modulators.html
Regards, Dana.
Logged
SaabFAN
Country:
Reply #2 on:
May 16, 2016, 01:33:21 am »
I doubt there is a cost-effective DDS-Solution available that can generate a sine-wave in the 5Ghz-Range.
A sine-shaping circuit to turn the square-wave into a sine-wave would probably the best solution.
TI has an application-note about that topic.
Logged
PM9610 Replacement for PM6654 Counter
Twitch-Channel - Gaming, Electronics Design, 3D Modeling, Random stuff
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
