To tsman:
It doesn't say explicitly that it's possible, but I just assumed like in Pulseview, if the channels are specified it could be possible to decode and export data according to the protocols used (SPI and I2C in my case). For example, Channel 0 to 11 for SPI and channel 12 to 13 for I2C. But once again, I couldn't find a similar case in the Internet, so I'm just assuming.
To Doctorandus_P :
Thank you for your answer! I hope so. I had already seen the video (many times :p) and read the doc. I have the same feeling as you but couldn't find a proof of that while searching for a similar case as mine.
Otherwise, worst case scenario, I could decode the SPI communication and for the I2C communication, I would still be able to export raw data and proccess it using a script.
I thought about buying a super cheap logic analyser but the shipping time is super long in Europe and I won't finish the project on time if wait for it. That why, I was super glad to find this community !
Anyway, thanks again both of you for your time. If you have any supports (known similar application, example of sigrok-cli + script,...) you think may be interesting for me, don't hesitate to share it with me.
