Around the web I have seen circuit designs where people were adding ~10k resistors to 75HC165 buffer parallel inputs in order to read DIP switch positions. I do not understand the requirement for these resistors from a current limiting standpoint as the buffer inputs have very large impedance, correct? Why are they used? If they are not used for current limiting, but instead for some high transient voltage protection, then I am not sure why one resistor per input is required instead of a single resistor for all inputs. Also, if it is for ESD protection, why not using TVS diodes instead?
Thanks!
