Author Topic: Gate driver chips with built in boost/power.  (Read 250 times)
Offline PsiTopic starter
« on: November 08, 2024, 04:50:26 am »
Has anyone seen n-mosfet gate driver chips with built in boost/ isolated-power, which are reasonably priced and not more expensive than the mosfet they are being used to drive.   I would class reasonably priced as like 50c.
All the high side driver ICs contain them so they cant be that hard to make.
Offline PCB.Wiz
Re: Gate driver chips with built in boost/power.
« Reply #1 on: November 08, 2024, 08:11:20 am »
You need to clarify what you mean by  boost/ isolated-power,
Standard half Bridge high voltage drivers like x2103 have boost/bootstrap and have high voltage level shifting.
Usually you do not need full galvanic isolation Hi to LO side as the bridge is connected.
Sometimes designers want 100% duty cycle, in which case you need either charge pump (for modest powers) or simple transformer isolation.
Nexperia have just released an example of SOT packaged transformer driver
https://www.nexperia.com/product/NXF6501DC-Q100
If you add that type of power path, you can get 100% from the lowest cost drivers.
