the whole point of X2 capacitors was that they're overrated?
It is hard to find the definition.
But from here
http://capakor.com/product/pdf/(21)General_technical_information.pdf?An X capacitor is used in Across-the-line applications
?In this location,a failure of the capacitor will not cause anybody to electrical shock hazards and usually will open the fuse and turn
the equipment off.
?Class Y capacitor is used in Line-by pass applications
?In this location,a failure of the capacitor will cause anybody to electrical shock hazard
X1 >2.5Kv,<4.0Kv High pulse:industrial printer,lighitng ballast or minicomputer which is connected to a 3-phase line
X2 <2.5Kv The most common class. General purose:Computer,hair dryer,FAX,hand power tool which are plugged into ordinary wall outlet.
X3 <1.2Kv - General purpose
Y1 8.0Kv For bridging double or reinforced insulation.
Y2 5.0Kv For bridging basic and supplementary insulation. Application:power supply used in data processing equipment.
Y3 none For bridging basic and supplementary insulation.
Y4 2.5Kv For bridging basic and supplementary insulation
So It is all about safety !.
And there i use them I really dont want to experiment to much.
The power lines to there they are connected are 20*8 mm
and a voltage 690V
Regards,
Lars
