Author Topic: DisplayPort to DVI  (Read 578 times)
Offline Pack34Topic starter
DisplayPort to DVI
« on: May 28, 2019, 03:09:30 pm »
I'm looking for the cheapest way to convert a DisplayPort output to a DVI-I (single link) input. Is it really as simple as wiring in a MAX9406 (or similar) chip like the app note below?
https://www.maximintegrated.com/en/app-notes/index.mvp/id/4313
Offline wraper
  • Country: lv
Re: DisplayPort to DVI
« Reply #1 on: May 28, 2019, 03:20:20 pm »
Most of displayport outputs are DP++ which means you only need a simple level shifter IC. They already can output DVI signal natively, just with different voltage level. http://www.ti.com/lit/ds/symlink/sn75dp139.pdf
