Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Testing a Custom Built Light Strip BEFORE Blowing my Computer up.
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Testing a Custom Built Light Strip BEFORE Blowing my Computer up. (Read 575 times)
DW1961
Frequent Contributor
Country:
on:
July 15, 2020, 07:23:26 pm »
I want to test my custom built (soldered) strip before smoke testing them on my motherboard.
I'm going to check for continuity and current, but will that do it? Or, is there something else I should check also?
Logged
spudboy488
Regular Contributor
Re: Testing a Custom Built Light Strip BEFORE Blowing my Computer up.
Reply #1 on:
July 16, 2020, 11:31:15 am »
Check for shorts between ground and power.
Check for shorts between ground and any signal that will be driven by the PC CPU.
Check for shorts between power and any signal that will be driven by the PC CPU.
Basically, you don't want to short the PC power supply or have the CPU try and drive a ground short high or a VCC short low.
Logged
DW1961
Country:
Reply #2 on:
July 16, 2020, 07:38:04 pm »
I'm less worried about the PSU unit. They are pretty well protected. I'm worried more about toasting the RGB fets. So I want to test the strips when I get done soldering them. The only thing I know to do is run an AMP and Continuity check on them. I'll also check the MB riser for correct voltage.
Anything else?
Logged
DW1961
Country:
Reply #3 on:
July 22, 2020, 05:12:50 am »
I'm talking about testing the strip itself to make sure it isn't shorted out in a way that will cause the Fets on the Motherboard's RGB circuit to melt.
Would just testing the strip with continuity and amperage do it, or are there other things that could case my MB's RGB fets to go "Up In Smoke" that continuity and amperage would not show?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
