I have an I2C bus connected to ATMEGA MCU.
The I2C is "normal", 3,3v , using open-drain and 10k pull-up resistors.
The slave devices work on higher voltage (24v) and in case of a mechanical fault, pinched cable, etc, there is a chance of 24v getting to SCL/SDA of the ATMEGA, which would be catastrophic for the MCU.
How can I protect the MCU from 24v on SCL/SDA ?
