Author Topic: The cheapest way to get 24V from 15 - 30V input  (Read 243 times)
Online bn
« on: September 18, 2020, 12:20:19 pm »
I am looking for the easiest and/or cheapest way to get 24 V with input voltage 15 - 30 V. Maximum output current is 0.5 A max (though 0.2-0.3 A will be acceptable too). After quick browse through TI/AD website it seems that 4-switch buck - boost with discrete switches or SEPIC is the way to go. Although I've already used 4-switch controllers with success (LM5175/LM5176) I feel like it is a overkill for such application. SEPIC seems like the way to go. Is there a easier solution to what I'm trying to acheive? I don't care too much about board space, simplicity and cost are major factors.
Thanks in advance
Offline tooki
Re: The cheapest way to get 24V from 15 - 30V input
« Reply #1 on: September 18, 2020, 03:12:30 pm »
Thanks in advance
Did you try TI’s Webench Power Designer? You put in your key parameters and it spits out a list of circuits, which you can then modify, simulate, and output a PCB layout for. I used it for a number of designs recently and it worked great.
Online bn
« Reply #2 on: September 18, 2020, 04:19:08 pm »
I'm using this board from TI, the TPS55332. It can be smaller because it has an LC input filter, overall its pretty simple.
https://www.ti.com/product/TPS55332-Q1
https://www.ti.com/lit/pdf/slvu319
Not sure if it will work in this case since it is only boost type controller and I need to be able to step voltage down.
Thanks in advance
Just did that and it spits out non-isolated flyback and indeed SEPIC. I guess I'll stick with the latter.
I was hoping maybe someone would be familiar with IC similar to TPS55160 but with higher output voltage capability, because otherwise it would be ideal choice.
Online Benta
« Reply #3 on: September 18, 2020, 05:56:54 pm »
SEPIC is a very good solution, especially when conducted EMI could be an issue.
You should check ON Semiconductor as well for suitable ICs.
« Last Edit: September 18, 2020, 05:58:27 pm by Benta »
