Hi everyone,
I don't think I fully understand the information some manufactures provide on thermal resistance. Normally, I would take that resistance (lead to ambient) multiply it with the expected power and then add the maximum ambient temperature. Now if that temperature falls inside the normal working range then I'm happy to use as is.
However, take this Zener diode (
1SMB5925BT3G Datasheet), the datasheet says that this device is a "3watt plastic surface mount Zener diode" which I can only assume it means that this diode can run find at 3Watts without heat sink. Now if you look at the table on the first page "maximum rating" it gives a thermal resistance from junction to lead of 25 °C/W with a maximum power dissipation of 3Watt where on the next row it says junction to ambient is 226 °C/W with maximum of 550mWatt.
Which thermal resistance should I be using if I want to pass 2.5W through it?
