And the phones are replaced before the connector starts to fail ..
when, not before.
Dropping my phone while charging from micro-USB did for it. Fortunately, it's still got a real charge socket (Nokia), and bluetooth for data...
We'll see how good these new USB3 wonder-sockets are, and whether there's a version that actually attaches to the PCB in a meaningful way. It's not as if it's been a process of continuous improvement on USB hardware so far.
Since the cables are getting fatter , heavier and stiffer, I hope that there's at least some effort put into defending against the levering effect of the cable.
Ah - the pictures from that earlier link
http://www.extremetech.com/computing/187882-reversible-usb-type-c-connector-finalized-devices-cables-and-adapters-coming-soondo suggest that they've listened to the whining about micro connectors being far too easy to tear off boards. Yay! (Although the standard calls it an 'optional hold down strap' - I hope it's the default on connectors.)
Looking further at the standard, I can't help but think we'll be seeing older sockets being used on low volume maker-style hardware for a while longer, or maybe some connector manufacture producing an easy-to-solder USB2-only variant. The full socket, with its 24 pins hidden underneath, on 0.5mm pitch, isn't going to be trivial to assemble or inspect. Hmm, maybe we'll see pigtails on products?
